Hi there
Do you have Windows 8.1 on your Laptop? If so, you can use a product called Netgear PTV3000 Push2TV.
Just to let you know, the inbuilt browser on the TV, does not have Flash support, therefore many streaming sites will not work though it anyhow.
In regards to the Sony NSZ-GS7 - I have not used it, so I cannot tell you want you cannot already google. My advice is to google it, read all the reviews (especially amature reviews on Amazon etc) and basically research it to ensure that it suits your requirements.
The only other option if you absolutely cannot connect your laptop to the TV and is cheaper than the Google TV is to have a look at the Android TV boxes that are around. There are quite a lot of them. One that caught my interest is this one :
www.amazon.co.uk/DroidBOX-iMX6-Android-4-2-Box/dp/B00DIJXZ6Q/
Other than that, good luck on your quest
