BluRay player streams from PC but TV fails...
profile.country.en_GB.title
theCOO
i recently bought a KDL-47W805A and BDV-E4100 - both the TV and BluRay player can play MKV files saved on my PC wirelessly, thanks to Homestream, but while the TV fails a few seconds/minutes into the video, the BluRay player has no problems playing it at all.
it's the same file from the same computer and both the TV and BluRay player were set up in the same way. the error message from the TV is "cannot connect to server" or something, but then the BluRay player will connect to it just fine.
i'd rather play the file through the TV since the menus are much nicer to navigate.
any idea what the problem might be?
thanks,
0 REPLIES 0
