HI ALL JUST PURCHASED THE BRAVIA 40EX403U, IT SAID IT WAS A 1080P TV
BUT WHEN WATCHING A HD PROGRAM IF YOU PRESS THE INFORMATION BUTTON IT SAYS IT IS 1080I
ANYONE KNOW WHY AND CAN YOU CHANGE IT
THANKS
Not sure any channels broadcast in 1080p - BBC HD doesn't.
http://en.wikipedia.org/wiki/BBC_HD
The TV support 1080p if its being fed a 1080p signal, e.g. from a Blu-ray Disc
Thanks
Thanks
Thanks for the information, one thing thats strange though is i have a digital stream hd freeview recorder and if i switch that on it then says 1080P, not sure why it says it with that but not with just the tv on
