Bravia tv stand
profile.country.en_GB.title
chriswoodyward
Bravia tv stand
where can i get an original tv stand for my 40inch bravia ( the one that came with the tv when purchased ) as the wife no longer wants it on the wall and i cant find mine,thanks
Anonymous
Not applicable
Hi there
I have checked various suppliers and unfortunately the stand appears to be no longer available.  The only solution that I can see is a full stand similar to THIS.  (just an example).
7 REPLIES 7
cablelogic
Model number of Sony 40" Bravia ?
We may have in stock.
Br, TG
seboyad
One option is a well known auction site which has loads of them for sale for various models if you want to have a quick search there.  CLICK ME
Hope that helps.
Hi how much would it cost for a tv stand for a sony bravia 40 in tv ref kdl40u3000u.
Anonymous
Not applicable
Hi there
shiftydixie
just bought  sony/bravia 40in kdl40r553cbv no screws to attach stand
Anonymous
Not applicable
@shiftydixie - your first port of call is to go back to the retailer you purchased it from.
hollywood1939
Just purchased this brilliant stand on ebay from a supplier called tvstandsandavcabinets.
It was £22 delivered and a gives a good, comfortable, adjustable viewing height. Screen size upto 50".
