Still hunting for the Network(or whatever) code to connect my dongle to tv and get my EX403 fully functional - John Lewis suggested I should use the code on the bottom of my Netgem Router but of the numerous numbers there which one am I supposed to use - experienced advice would be great,regards
I'd call your ISP as they should be able to advise..
Hello,
When I set up my home network, I set up security on the wireless settings on the router.
This sounds like the network key that was used when you set up the router.
Maybe worth looking at the menu for the router on your PC to see if the network key is visible.
Maybe worth looking in the instruction manual for the router.
Hope it helps.
