Hi, I am trying to set up wireless connection on my Bravia TV, but need to enter an underscore ( _ ) as part of my passphrase. Is it possible?
Message was edited by: saffron
Yup - just checked on my 2011 model, so *likely* the same. When you get the onscreen keyboard up, press the blue button on the remote a few times and it will toggle through to the character input page where you can enter £$%^&* and all that good stuff including _
Thanks
Thank you so much. That worked, and such a simple answer.
I bought a smart tv model KD-55XF8796 and my on screen board is not entering underscores and ampersands. I tried to use blue button as well and it does not work. Very frustrating.
