Having had no issues suddenly got yellow triangle with ' No signal check your antenna connection'
The HDMI is connected from TV to Sky Mini Box ( green light on ). No issues with main Sky Q Box ?
Appeciate anyones help or is it a Sky problem ?
@The-Chimp wrote:Having had no issues suddenly got yellow triangle with ' No signal check your antenna connection'
Hi @The-Chimp
It sounds like you have selected Analogue or Digital TV Input. Try changing it back to the HDMI input that the Sky Q Mini box is connected to. Keep pressing the Sky Q remote TV input button (bottom left) until it is back on the correct Sky Q HDMI input.
