- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Filename size limit for SMP-N100
Is there a limit to the length of filenames that the SMP-N100 can detect? When I navigate to the correct mp3 folder both by streaming or directly by a hard drive plugged into the USB I get a message stating that no files are present even though they are.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You are accessing the music files via the music icon right?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have the same problem but with video files,i never tested with audio files.
I made some tests and i believe is a bug in this firmware because the player can't see files which are in more than 4 folders, for example if i wanna play movies from folder \bluray\720p\action\movieName\movieNamePart1\ it won't play but after moving files to \720p\action\movieName\movieNamePart1\ i can see and play the files.
I observed other bugs like:
- the media player only see first active partion from your hard drive, i had to merge my partitions to see all the movies from my hdd
- some movies aren't played, i believe the audio bit rate is unsuported
