I would like a Freesat HD recorder that uses sony sync to go with my Sony HD TV 40EX403 .
Can anyone advise what I am able to use?
No DLNA and BRAVIA Sync (a.k.a. HDMI-CEC) are two totally different technologies assuming thats what you are referring to.
I'm not that familiar with Freesat PVR's to be honest, but a quick search of the usual review sites should I'm sure elude some results.
Thanks
As far as I can remember from the resource docs you need to use DLNA equipment to use the sync function. Look for the label / specs when you research the equipment.
