help getting sony dongle to connect a sony KDL-32EX403 to internet
profile.country.en_GB.title
gingerkinter
I have just bought a sony dongle to connect a sony KDL-32EX403 to the internet. After painstakingly putting in the network name and password it finds the network but fails to find a signal?
If I check connection the screens says
connection method: wireless usb
wireless device: ok
network (SSID): my network name (that works on my laptop to get wifi)
signal strength:    -
security: WEP
IP address: a load of numbers and dots
subnet mask: different numbers and dots
default gatway: zeros and dots
Primary DNS: zeros and dots
Secondary DNS: zeros and dots
I use an airport and a nectar router with a apple laptop and it connects ok?
Can anyone offer some advice? Do I need to upgrade anything?
Thanks for your help. G
Catmambo
Contributor
Try turning of the WEP key and connecting first so you can update the firmware..
Thanks
1 REPLY 1
Catmambo
Contributor
Thanks
