I have recently bought
and paid for installation but installer didn't stay to see if iplayer would work from desktop. I have not been able to connect the computer to the Dongle. Any ideas?
Hi CaroleB,
The BBC iPlayer (Beta) only works with latest firmware (software) versions. As your TV is new you may need to update it, which can be done automatically or downloaded onto a USB stick.
To access your PC's wirelessly you need to make sure they are all sharing on your home network.
Hope that helps,
Cheers,
Hi CaroleB,
Hope that helps,
Cheers,
