How do I turn off the picture whilst listening to digital radio?
profile.country.en_GB.title
being_thick
Have just acquired a KDL40EX403 TV and am trying to find my way around it.  The manual says you can turn off the picture whilst listening to audio such as digital radio.. However, I cannot find how to do it.
jtonline.info
It is my understanding that you can set the TV to display an in-built screensaver instead of the broadcast radio station info:
System Settings | Radio Display
or
You can turn off the picture with sound remaining:
System Settings | Eco | Power Saving | Picture Off
On my TV its possible to get to the Power Saving menu quite quickly by pressing the Options button on the remote, however I don't know whether that's possible on the 40EX403 model.
4 REPLIES 4
tallkeith
Doesn't look like this can be done - pretty naff!
I've tried everything I can think of
jtonline.info
or
being_thick
The second suggestion works - you get to the power saving menu from the home page under system settings.
Thanks.
jtonline.info
You're welcome :slight_smile:
