How to change Authentication to Normal and get Pre-Shared Key in my KD-55X7000E.
profile.country.TW.title
luvmex
As title,
My module is KD-55X7000E ( 2017y )
I'm trying to change the authentication to enable and wont to get the PreSharedKey( is that same as WPA key? )
If so thanks in advance.
2 REPLIES 2
EdwinaU
Hi Luvmex,
We'll check to see what's possible and let you know what we find. Meanwhile, maybe some of our members can offer some advice.
Best wishes,
Ed
Win_88
Specialist
Hi luvmex
I'm not sure I completely understand what you're looking for.
If you're trying to connect the TV to your Wi-Fi without having to enter a password then you can either use the WPS button on the router which should temporarily allow you to connect without a password before putting the security back up.
If you decide to use WPS, go to HOME - Network - Wi-Fi - Connect via WPS
Win_88
