On my KDL-52W3000 LCD TV the input symbol on screen eg AV6 HDMI2 no longer disappears after a few seconds and whatever is selected stays on the screen, the format info eg 576p info does erase after a few seconds. Any idea what is causing this?
Pretty sure you have simply toggled one of the buttons at the top of the remote like the 'info' i+ button or something. Press it again a couple of times and this should fix it.
thanks
Your suggestion was spot on! -problem fixed.
Thank you so much.
Kindest Regards,
