Is it possible to connect a keyboard to a Bravia KDL-40EX403?
profile.country.en_GB.title
vicsam35
Is it possible to connect a keyboard to a Bravia KDL-40EX403? I have attempted to connect through the USB port but get the message ' component not supported '.
Catmambo
Contributor
No its not unfortunately. BRAVIA's don't have the PC drivers installed on them which would be needed to make the peripheral work.
thanks
4 REPLIES 4
Catmambo
Contributor
thanks
jamiejamiejamiejamie
Are there any plans to make it possible? For example, could you iRemote on the iphone be developed to work with the TV?
Catmambo
Contributor
Not on the 2010 models unfortunately as the platform can't support it.
thanks
Abbey99
The chap who installed my KDL-40EX403 suggested that instead of accessing the internet through a dongle, a better idea would be to connect a small desktop PC. Then I would be able to use a wireless keyboard, rather than the on screen one. Haven't tried it yet though!
