KD-65X7000F How to disable Channel information?
Popup bar up which resulotion and other stuff show in.
It's annoying for multiple reasons.
One of which it randomly appear while using my laptop through HDMI, it's rare but it's annoying and I don't know the cause of it.
Plz help and thanx.
1 REPLY 1
Win_88
Specialist
The information bar appears when the TV detects a change in the signal it's receiving or when an interruption happens (due to the cable moving for example). If it's a one time thing every now and then, I'd recommend trying a different cable if you have one lying around.
Win_88
