I've had my LG 32LB580V TV replaced under warranty with a Sony KDL32WD751, which is apparently like for like.
On my LG, I was able to control the TV set using IP commands via my Home Automation system. I understand Sony Bravia TV's have similar capabilities via TCP/IRCC, yet a port scan suggests the KDL32WD751 probably doesn't support this.
Can this be confirmed/any light shed?
Hi James,
Welcome to the community.
Please have a look here at pages 10, 11 and 23 of the KDL-32WD751 manual and let us know how you get on.
Thanks,
Pascale
Thanks for the reply. The TV is successfully connected to the network via Ethernet cable (it sits on a structured network).
The problem Im having is that there seem to be features missing from the firmware, I assume this is due to the model being "low end", though I'm not quite sure how resource heavy a simple HTTP/IRCC service would actually be!
This is what I see when I port scan the TV... browsing to the http://IPofTV:portnumber reveals a 404 error.
