KDL-32WD751 Keeps dropping the WiFi Network
tcampton
The TV keeps dropping the Network Connection, consequently if I press the green button to watch a BBC programme from the start it either doesn't work or is stuck saying "Please wait". I usually need to connect to the network on a daily basis, it doesn't remember it.
3 REPLIES 3
Pascale_F
Hi tcampton,
I'll see if I can track down an answer. Maybe someone else in the community has an idea in the meantime.
Thanks,
Pascale
Joe_Dohn
Specialist
Have you tried restarting both your router and TV? You can also double-check that the TV is up to date, since that can usually cause issues with connectivity.
tcampton
Hi Joe,
Yes I have tried restarting both. No joy. I have Software Version:-
8.219-1000-1.330-01
Which according to the Sony Website is the most recent version.
Cheers,
Terry
