KDL-42W705B Playing .VOB DVD Files Continuosly
304092aj
Новый
I have tried a couple DLNA media server prog's(Twonky and Serviio)and they work okay BUT how can I get the DVD files in each folder from my Windows 7 server to run continuosly, in other words without having to start the next .VOB file and without having to modifiy the contents of each DVD folder, for instance joining the .VOB files with an application as this would take forever, there has to be a way to do this.
Also after removing uninstalling Twonky I now have a dead Tab at the top of the page next to Serviio on the TV, how can I remove it?
Thanks in advance for any advice.
0 ОТВЕТОВ 0
