KDL32WD751 remove info banner on HDMI 2
LJTwice
Good evening,
Wondering if anyone can help. I have this tv spare and decided to hook it up to the PC to use as a monitor but while connected to the HDMI port, the info bar is pretty much always present. It may disappear for a few seconds but then it always pops back up covering the top 1/5 of the screen.
I have been searching the forums and the options to remove the info bar in channel setup is not there. It also only momentarily go's away when you use the i+ button above the main navigation buttons.
If any one can help with this, I would be greatly appreciative.
Regards
A very frustrated tv owner.
1 REPLY 1
Anonymous
Not applicable
Hi there,
Have you tried a factory reset?
Best wishes,
M
