kdl55w805
lyndtok
kdl55w805
Hi, can I hook up a standard laptop 2.5 internal HDD (via usb) to the TV to record stuff? Or does it have to be an actual USB HDD?
Tags (3)
Anonymous
Not applicable
HI there
It is generally preferred that you use a powered HDD (ie one that doesnt just rely on power from the USB port) as you will probably experience less problems that way.
1 REPLY 1
Anonymous
Not applicable
HI there
