Hello. I have the tv wega KLV-L32M1. Can i connect it with my laptop, so i can see youtube etc? It has only 3 scarts. Anyone can help?
depending on the video-out of your laptop you might need an adapter. maybe something like this one on the picture:
and then you need audio-out adapter:
and you plug them into RCA video-in of your TV with corresponding colours.
if you really need to use the the scart input, you might need to use this adapter:
