missing channels
profile.country.en_GB.title
rondylan
missing channels
recently purchased bravia kdl40ex403 and upon tuning in to freeview channels there are some missing , notably bbc etc.  on auto tune i only pick up 37 channels NO hd channels. Tried to manual tune but no better, just seemed to skip past channels. I have 3 other tv sets in home which although they only pick up certain channels on auto tune , on manual tune they pick up at least another 12 or so channels including bbc etc..  How can i pick up bbc etc on the bravia ?  Any ideas ?
2 REPLIES 2
gjohns
Sounds like you need an aerial upgrade
I had a problem with my bravia KDL-32EX403 in auto tune it found all the chanels but would not store them, I got NO SERVICE STORED message on the screen. I finally solved it by disconnecting all peripherals and only the aeril connected, then did a factory reset. then auto tune again and it worked perfectly first time.
I hope this helps anyone else having tuning trouble.
profile.country.hr_HR.title
DamacizSi
You can try to chose full scan in auto start up...
