The TV is only 4 years old. It is as though someone is quickly turning up and down the brightness. Do we need a new one or can this be fixed?
Thank-you
Hello,
Probably difficult to diagnose by mail, but does sound like a problem with the tube (CRT). Although it probably could be fixed it will be costly if it is the CRT.
Best thing to do is contact a service center in your area and see if you can get a free estimate
May be worth checking with post code checker for nearest service center
http://support.sony-europe.com/repair/asc/asc.aspx?site=odw_en_GB
Hope it helps.
