Netflix problem on KDL50W829
Hi
I've had this telly for a few weeks now and in the last few days, Netflix doesn't work.
I just get the message "Netflix has encountered an error"
Has anyone had the same issues?
Thanks
1 REPLY 1
Anonymous
Not applicable
Hi there
These types of problems normally is at your internet connection or ISP.  But lets go through the following:
  • Ensure that you have the latest firmware installed.
  • Are you able to use other applications on the TV (ie iPlayer/YouTube etc?)
  • Try signing out of Netflix - and logging back in again (instructions : HERE)
  • All else fails, try a factory reset of the TV.
  • Check your ISPs forums to see if others are having problems.
Hopefully one or more of these helps :slight_smile:
