I am trying to access my photo account setup in Picasa on my Sony TV. When I try to log in, the TV displays "unkown error". Any ideas whats causing this and why I cant access my web album through the Picasa internet TV application?
Do any of the other web services work at the moment? Sometimes just a case of leaving it 30 minutes and trying again as it could be google are doing something on their side.
thanks
I had to ensure that the pwd use to login to the internet services did not contain any special characters. Once I had changed my pwd it worked fine.
Hope it helps.
Sony: Maybe something to verify and adjust.
Hello,
I had the same problem and it seems to work now.
I heard somewhere that the problem was not happening when using a new google account (i dunno what is "new").
So if you create a new account then it should work.
As i wanted to use my "very old" google account, i tried something new :
First I logged off from my google account (https://mail.google.com/mail/?logout&hl=en-GB)
Then I went on http://picasaweb.google.com/home and decided to create an account : by clicking the button at the bottom right of the page. Then i entered my "very old" gmail address in the first field at the top of the page. Entered the current pwd...filled up all the fields, validate that.
I went back to my TV, in the picasa widget, entered my "very old" login (without @, something like toto.tata and not toto.tata@gmail.com), and the password. And it worked !
Best-
Arnaud.
