Hi
We are experiencing tinny/fuzzy sound quality on our braia KDL-37p3020 tv. It happens on and off. Can any one suggest any ideas to cure this please x
You need to give as much more relevant data like, is anything connected to TV, is it connected to cable or antena, did you do reset to factory settings manu-settings-set up-slide down in manu and make reset ...after that same path but this time chose auto start up and search all achanals again if is cable provider, chosing full scan, if is antena quick scan...did You try to adjust sound in manu-settings-sound adjustmant...do You get same sound when You connect DVD player and whatch it on TV ect.
R
Damac
