Remote control functionality shortcomings for Bravia TV (KDL-43WD750)
gk-rhodes
I have a KDL-43WD750 with firmware v8.213-1000-1.330-1. Here are a few functionality shortcomings I have spotted when using the remote control:
1. When the TV is off and I press a number on the remote, the TV after turning on shows not the channel associated with this number but the channel that was showing during the last turn off.
2. When turning the TV on, then change channel and then press the "previous channel" button (the small button above the mute button), the TV does not revert to the initial channel. It only works after I change the channel once more.
3. It would be very helpful, after pressing the "GUIDE" button, to be able to choose something from the programme, that will start after some time, so that the TV automatically switches to that, if in the meantime, I'm watching something else.
1 REPLY 1
EdwinaU
Hi there,
Welcome to the community.
Please try the tips here to troubleshoot your remote control.
Best wishes,
Ed
