Sony Bravia KD65XE7093 bought from Amazon UK
Swego4
Hello, I purchsased a KD65XE7093 a couple of months ago and recently I've been getting the info banner popping up frequently displaying HDMI 2...
I've factory reset it, replugged the HDMIs into other ports and tried new cables too but still the same.
Is there any way to disable it?
This is not an Android TV so I can't do the Channel Setup thing.
1 REPLY 1
Vanilla_
Contributor
Hi Swego4,
I believe this depends on the signal received by the TV. This banner will pop up when the signal output from the connected HDMI device changes. I've found that the only solution to this would be by force the connected device to output the same audio format.
Vanilla_
