Sony Bravia KDL-46EX653 Screen Mirroring
Hunda67
How do I mirror the screen of my Samsung S6 on my Sony Bravia?
I can connect the phone via wifi direct but then what - if I come out the wifi direct menu on the TV the connection is lost?
Thanks for any help.
2 REPLIES 2
IamNic
Hi @Hunda67,
normally you just need to be connected to the same network as the TV and then pull down the quick access menu from the top of your phones screen.
There you will find a google cast symbol:
By clicking it you will be asked to which TV you want to stream your phone screen to.
Select your TV and off you go (hopefully).
- Nic
Hunda67
Thanks for reply but it doesn't work. Both TV and phone are connected to same wifi network but phone doesn't see TV.
If I activate wifi direct on both tv and phone they can both see each other but when I use google cast the wifi direct is turned off on the phone and they don't see each other,
Tags (1)
