- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Sony Bravia TV broke my Pen Drive?
Hi all, i recently bought a sony bravia tv, but i have had difficulty recording stuff onto a 32gb pen drive i popped in the back, it was always a bit hit and miss when recording stuff. Now the drive is no longer recognised by the tv, i can't unformat it and when plugged into a mac it no longer recognises it either... It does still appear on Disk Utility with the partitions that the TV put on the drive, but it cannot be read or cleared to restore it to everyday use... Any help would be greatly received...
The TV model is a Sony Bravia KDL40HX753BU.
Message was edited by: weblabrador
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yay, it's now broken another one, and it's now completely unusable too..! It's great to see SONY really taking customer servoce and product testing to a new level... (that was sarcasm, btw, i'm never buying another sony product after this.)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
It could be worse - The pen drive breaking the Sony TV?
Anyhow - What makes you think the drive is broken? What are you trying to do? What happened before hand? Did you go through the "de-registration" process ? I dont suppose you unplugged it, whilst data was still being written?
As you can see, plenty of questions here.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi
As Quinnicus wrote, there are only a few info about issue, but, lets try…
There’re several methods in order to “clean/recover” removable media (HDD, SD, etc).
--Visit removable media producer’s site. Many times, there’re dedicated/customized software to do so.
--For SD cards and many USB stick memories (that using the same standard), use SD Formatter - (SDcard.org) (You must use not only “Format” option but also “Format Size Adjustment ON”)
--But the best, with Windows OS, is “clean” or “clean all” option of “diskpart Command-Line”
http://technet.microsoft.com/en-gb/library/cc766465(v=ws.10).aspx
http://support.microsoft.com/kb/300415/en-us
On “Command Prompt” (cmd.exe) rightclick” with mouse and select “Run as administrator”
On Command-line:
diskpart
list disk
select disk XX
clean (or clean all that deletes everything on media (secure erase, without possibility to recover data anymore), but it’s too slow!)
Then format media with or without “diskpart”
Warning! Be very careful when using “select disk XX” command! If you select a wrong media, you’ll erase all data on partition/disk selected!
Here’s an Example of diskpart clean and clean all commands
Jannis
Non mi aspetto nulla. Non temo nulla. Sono libero. - I hope for nothing. I fear nothing. I am free. (N.K.) |
