Sony Channel Editor..........
Jonnie1266
Contributor
Has anyone had any success using the recent Sony Channel Editor tool?
When I try the following instruction I have no list to re-order!
Modifying the channel list on your computer:
  • Insert the memory stick with “sdb.xml” into a USB port on your computer.
  • Launch the Channel Editor tool and open “sdb.xml”.
  • Re-order the programmes in your channel list.
  • Save your modified channel list onto “sdb.xml” in the memory stick.        Please post replies so I can troubleshoot my issue.        Regards
If it ain't broke don't fix it
1 REPLY 1
Mick_D
Hi @Jonnie1266
I noticed your post on the other thread, which might be the best place to post your updates and further questions. It keeps your question in context and if you 'bump' it to the top of the list it will likely attract more responses.
The tool does seem to be challenging a number of people, so hopefully a solution will be found soon.
Mick
