My TV a Bravia KDL 40 is attached to a virgin Tivo box. When i switch from HD transmission to standard I lose sound. Only way to get it back is to switch the TV off then on again
Hi main_man,
Welcome to the Community.
It might be worth performing a reset or a Factory Data Reset on your KDL-40WE663. Do let us know how you get on.
Thanks,
Pascale
Glad to hear that has resolved the issue for you 😃
Thanks for letting us know.
Best wishes,
Sean Mc
Hi there,
Can you give me the full model number of your TV?
Best wishes,
Sean Mc
My TV model is a KDL 40WE663BU
Hi main_man,
Thanks,
Pascale
I've reset the TV and everything seems to be ok right now.
Thank
