Hello,
I've just bought a Sony Bravia KD43XE7003 and I can't find a TV bracket that will fit anywhere!
The VESA measurements are 100 x 200. Ideally I'd like a movable bracket. Can anyone help?!
Hi @gibs132,
the default wall mount is called SU-WL450, yet it is not movable from what I can tell.
Other mounts might fit, so simply look for a mount with the right measurments (100x200 like you said).
- Nic
