I would like to know what USB stick is to be used to watch movies on a KDL-32EX403
Someone can correct me if I'm wrong but any standard USB stick should be readable by your EX403. I have the 40" 403 and I've used several different usb manufacturers from no name to brand names and all have been read.
Just copy the movie(as long as its in a compatible format) and go to movies icon on main menu then scroll down to usb device.
Be warned file formats/code formats are a big problem and from reading other posts you'll find file playback hit or miss.
I think the file structure of the usb stick has to be formatted to FAT32. Most sticks are formatted to this by default, however it limits the file size to 4gb. Which is a bit rubbish. I'd like a firmware upgrade to recognise NTFS or FATex.
