profile.country.en_GB.title
VendeeChris
USB HDD Fail!
Hello I am trying to register a USB flash drive to the TV to record but it keeps saying "fail" after a few seconds initialising - help anyone?
3 REPLIES 3
Anonymous
Not applicable
Hi there
May I ask what model TV you have?
VendeeChris
Hello and thanks for responding! The TV is a Bravia KDL 22EX553 which we bought for the kitchen and had hoped to be able to use the timeslip on it but as I say, it refuses to recognise the USB flash drive. I ordered a 64Gb one especially!
Anonymous
Not applicable
Hi there
Just looking at the manual for your TV
http://pdf.crse.com/manuals/AE7S100811/ENG/c_usbrec_europe_set.html
USB drive must be between 32GB - 2TB = Check
Even though it doesnt say, the drive must be formatted to FAT32 first. So check that on your PC/laptop.
I cannot 100PERCENTAGESIGN confirm that USB Flash drives are supported. Everything refers to Hard Disk Drives (HDD). I doubt it should make any difference to be honest (as you cant find a 32GB HDD as the specs would suggest anyhow), If the drive is between the sizes and formatted to FAT32, the drive should then register.
Anyway, first thing to do, is check/convert the USB drive to FAT32
Hope that helps.
