i have purchased a bravia KDL 40NX713, mistakenly i used the serial number on the back of the tv, instead of the serial number on the box, which i later found out on the sony website is the serial number you need, shoul i contact the vat helpline? could anyone tell me if the serial number on the back of the tv is the same serial number on the box.
THANKYOU!!!
On my 37EX403 the 7-digit serial number xxxxxxx on the back of the TV is easier to find and is the same as the number embedded in S01-xxxxxxx-A, in the lowest of 4 bar-codes on a label on the box. Think you should be OK.
