I have a problem with my Sony KDL-37S5500 tv when people talk it sounds like the speakers are vibrating, I have tried altering the sound settings all to no avail can anyone help or is it a warranty job?
Hi sheene
If you've tried altering the settings and checked other input souces like video of DVD and its still the same, then yes get it repaired under warranty. Good luck.
Hi slowtrain thanks for the info will get it checked out.
Did you manage to get this fixed / what was the solution?
I have a Sony Bravia KDL-40EX503 with the same problem...
Nigel
