i have a sony bravia KDL 40CX523. When i change from standard channels to hd channels, the volume goes sky high, would nearly burst your ear drums. tried adjusting sound ratio on tv and digital box settings, but no help.
cable guy,says its tv, because when you use scart cable,sound is fine on hd channels, just when you connect via hdmi cable, volume problem is back, any help appreciated. would like to be able to watch the hd channels,without racing for the remotes as quick as possible and before i annoy the neighbours,,, thanks
Hi there
Have you tried adjusting the volume offset in the sound settings? Ensure also that Target Input is Current input, and current input is the device that is in question.
See:
http://pdf.crse.com/manuals/iManuals/eng/CX52x_o32/st_soundmenu.html
Hi there
See:
