What does the "U" stand for?
profile.country.sv_SE.title
lalalex
What is the differences between this two sets:
KDL-32EX403
KDL-32EX403U
Does the specifications differ on these two sets?
profile.country.en_GB.title
Ian-Campbell
I would agree that the 'U' suffix at the end of the model number stands for United Kingdom and TV would be fitted with UK plug
On some of the older model SONY TV's the "U" suffix meant "United Kingdom". Continental Europe had the "E" suffix. The only difference between the U and E versions was that the UK model contained analog tuners that can only tune to UK-style PAL-I broadcasts. The E versions contain analog tuners that can tune to PAL-I as well as all of the other European variants.
Digital functionality should be the same on both versions, so it should be entirely possible to use a Continental European import in the UK with a plug adapter.
regards
Ian Campbell
2 REPLIES 2
KDL-22PX300
Identifies region.
United Kingdom.
Ian-Campbell
regards
Ian Campbell
