What is the Best Configuration?
bigwut
I have just purchased the following Sony kit and have a simple question - what is the best way to plug  it all together?  I had assumed that I could just plug an HDMI cable between the tv and amp, and another between the amp & blu ray.  However, the chap at the shop told me the one of the link doesn’t support audio on HDMI soI would need to use an optical cable of phonos.  So before I take the amp out of the box, can you tell me how do I link these together for best results?  Thnaks!  The equipment in question is  - TV  KDL-40EX503. BluRay - BDP-S370, and Tuner Amp - STR-DH510.  Only other kit I have is a BT vision box.  Thanks!
1 REPLY 1
profile.country.en_GB.title
Catmambo
Contributor
They all support HDMI so not quite sure what he is referring to? I can't see any problem connecting via HDMI, thats the preferred way of connecting...
thanks
