Bios update problem
dario1467
Bios update problem
I have a problem concerning bios update
My vaio is SVF15A13SAP
I downloaded R0250DA bios
And started flashing
First, the windows restarted and saw vaio logo but it vanished quickly and got a black screen
Waited for a long time but nothing happened so I pressed alt+ctrl+delete
The windows opened normally but the power button is not working anymore
I have to press assist button to power on the laptop
I can't access the bios
The bios has not updated and still have the old version R0200DA
Please help
5 REPLIES 5
Sean_Mc
Hi Dario,
Welcome to the Sony Community.
I'm looking into this for you and will update this thread as soon as possible.
Best wishes,
Sean Mc
Win_88
Specialist
Hi Dario,
Were you still using the same operating system that your VAIO came with or did you upgrade that at any point? I'd recommend trying to do a system recovery.
Win_88
dario1467
I don't have the recovery anymore
And yes I have done an upgrade
Win_88
Specialist
Hi again,
I think you should get in touch with a Sony service centre for this one. You can use this link to locate your nearest one.
Win_88
dario1467
I could solve the problem of starting the laptop by removing the battery and ac adapter then reconnecting them
Now when trying to update the bios it gives an error message invalid firmware image
do you have any solution to this problem
