VGC M1
Hi, my VGC M1 has stopped working. I think the power unit is gone as there was a burning smell at the back. Can anyone help me?
Hi matrix12,
welcome to Club VAIO..
If there is a burning smell I suggest you either contact Sony Vaio support, you can do this either by phone or via e-Support, use the following link to find the contact details: Sony Vaio Support
Or
See if a local repairer in your area to investigate and quote a cost for repair..
