MS keyboard screws with Vaio keyboard
hoobsdad
Hi all,
my first post, but somewhat desperate to work out why this is happening;
I have the original install straight out of the shop on my FZ31Z and on top of that have MS office 2003, Adobe Photoshop CS3, Acrobat 8 pro, Illustratror CS3, Lightroom 1.4, ESET Nod32, MS Foldershare, Copernic Desktop search, use Firefox V2xx, Foxit and run Directory Opus 9 as my Explorer replacement....Think that just about covers it.
When I am working at a desk I use a Wireless Microsoft Multimedia 1.1 Keyboard with a wireless Intellimouse Explorer mouse - which works fine - just by plugging in the USB receiver, but when I return to my laptop keyboard, either with or without the wireless keyboard plugged in then the keys on my laptop no longer type the correct keys. As a for instance, it appears that the "i" key types a "5" instead...and various other keys along the top qwerty row do something different. Only by running system restore to a previous time can I get my keyboard on my laptop back to its original state. I can use the Intellimouse without this problem occurring, so it's something to do with the wireless usb keyboard and the Vista drivers conflicting with Vaio keyboard drivers.
Can anyone help....?
2 REPLIES 2
Thalamus.
Champion
Hi hoobsdad,
welcome to club VAIO.. :slight_smile:
I suspect that your wireless keyboard has Num Lk (number lock) enabled, this could explaine why the "i" key types a "5" instead, hopefully pressing the Num LK key top right of your keyboard should solve the problem.. :slight_smile:
As your Vaio keyboard does not have separate number key's like your wireless when the Num Lk is enabled your U I O P [ J K L : M and ? key will display the respective number or symbol..
hoobsdad
thalamus, sadly, I have been unable to resolve this. It's some kind of software/hardware glitch. Essentially using a wireless keyboard (MS) works fine, but when I return to the Vaio keyboard, it's the Vaio which has a screwed keyboard.... as per my first post and I really have no way of resolving this. I am surprised that no one else has had this as it's definitely an issue with Sony and MS wireless keyboard.
