how can i use pico player.it requires computer name and password ..anyone has the same system so i can connect to see ..
PicoPlayer can act as a client-software, allowing you to access your Capsules from different locations
If you don't have a computer with GigaPocket on your local area network or on the same machine as PicoPlayer, then the latter is useless! Just use the GigaPocket Video Explorer instead.
PicoPlayer was designed for two reasons:
1. To connect to a computer running the GigaPocket server to watch video across a network.
2. To play GigaPocket video capsules on computers that do not have GigaPocket.
