RX202 RAM upgrade
irm
RX202 RAM upgrade
My RX202 has 256mB RAM which I want to upgrade to 1gB (ie 2 x 512mB cards).
Do I need to use specific manufacturers memory to match the motherboard, or will any work? (I have tried using a borrowed generic 256mB card but the system would not start - I have read that some motherboards are not compatible with all memory manufacturers.)
Ian
2 REPLIES 2
EzDoezIt
profile.country.en_GB.title
robpaxton
Check www.crucial.com/uk or www.offtek.co.uk for memory, both guarantee that their memory is compatible.
Regards, Rob
