RX403N
MRNEWYORK
Посетитель
RX403N
Hey guys after buying the Sony RX403N i must say i am impressed with it. Any one else use the same desktop? Let me know what you think Justin
2 ОТВЕТ 2
sachinbhonsle
Посетитель
:slight_smile: Hi, I have got one too. It's great except for the openmg software. I just cannot check in my existing minidisc collection onto the hard drive.
Stephanius
Посетитель
The problem is that the NetMD is a cul-de-sac. You can export files to it, but you can not import. The audio files you may have in various formats are converted for MD use, but a backwards conversion is not provided - depending on the quality settings made it would not make sense.
You can not copy from MD to HDD, you can only decrease the number of check-outs you have by removing content from an MD.
