Sony CR31s Sound Too Low!! Help Please! How Can I Get Louder Sound??
meclive
Hi, I have a sony cr31s but the sound does not go loud enough. Its loud enought to hear most things when at 100% but if you play music I would like it to be a bit louder because it really isnt that loud at all, is there any drivers or software updates that will sort this out and make my sound higher? thanks.
1 REPLY 1
davweir4
hey there, not sure if this will help or not but something to try! I had a simiiar problem with my NR series even when i had my volume set to 100% it was because i had other programs turned down mines in particular was limewire granted most things like media players etc dont effect system volume but limewire did with mines something to try nothing lost nothing gained let me know how you get on. good luck
