sony vaio sve1511c5e problem with ram
huskyfirst1
Hello, for some time I noticed that my ram was indeed overloaded manager processor and ram spot indicates that my ram is at 70% (at time of writing) then
I do not do anything that uses a lot of ram. and 10 min after ignition pc.j 've all tried scan and repair with vaio care nothing works
I have a sony vaio laptop core i5-2450M sve1511c5e 6GB of ram, which is 11 months.
or just to overload the ram?
is that formatting via recovery solve the problem?
thank you
1 REPLY 1
rich912
Contributor
Hi huskyfirst1,
Have you checked in Task Manager > Processes to see whether any application is using more memory than expected (you may need to click ‘show processes from all users’) and also run a FULL virus scan using more than one utility.
If the problem of high memory usage is a corrupt application then a factory reset should cure the problem but of course this is a long winded process so I suggest you try to find the culprit before going down this road.
Rich
Go n-éirí an bóthar leat
