MY LAPTOP SONY VAIO VGN-SR19VN AND I COULDN'T FIND DRIVERS WIN7 32bit !! HELP !! THANKS !
Hi Stergios
Here, it seems to be available driver for Win7 32/64bit for your PC:
http://www.sony.co.uk/support/en/product/VGN-SR19VN/updates
Jannis
Non mi aspetto nulla. Non temo nulla. Sono libero. - I hope for nothing. I fear nothing. I am free. (N.K.) |
<Foreign language content removed by Community Manager>
jan2011're n panathaaaa! These are! I found the edge finally! all OK! The only problem is now with the FN + buttons SOUND EXPOSURE
Γειά σου Στέργιο.
You have to install with a “certain order” drivers and Utilities.
For example first “Shared Library” and then “Utilities”!
These, on USA Sony Support, are about the instructions of a clean Windows 7 install:
http://esupport.sony.com/US/p/support-info.pl?info_id=1313
Γιάννης
